matching original paint
Old Apr 22, 2015 | 10:53 AM
rktolds's Avatar
Is it impossible to match faded factory paint? I will start on a 72 flat top wagon and have fenders from a 71 vista for this car. I'd like to match the fenders the best I can? Any chance? Thanks.
Old Apr 22, 2015 | 11:28 AM
83hurstguy's Avatar
I'm going to try sometime in the future... going to have to bring in a body panel (fender) for scanning purposes and see what they can come up with...
Old Apr 22, 2015 | 12:52 PM
rktolds's Avatar
Good call about getting it scanned. I'll have to look into that down here.
Matt
Old Apr 23, 2015 | 02:48 PM
I've never had luck with spectroscope scanners. Plus the new paint never fades to match the old, so even if you get a match when the paint goes on, after a year the car'll look like a camouflage pattern. Unless you never drive it on sunny days.
Old Apr 24, 2015 | 09:28 AM
Don R.'s Avatar
I have used the scanner method to match paint three times with excellent results, but the paint being matched was in pretty good shape. I assume you have tried a serious buff-out? Also, I used this method with solid color paint only, I doubt it would work with metallic. Good luck.
Old Apr 24, 2015 | 09:51 AM
Yeah, I should have mentioned my experiences were with metallic.
Old Apr 24, 2015 | 01:16 PM
Rocketowner's Avatar
You very seldom match paint without "Blending the adjoining Panel" . In other words, if you are painting a front fender ,fade it into the door and hood.Look up or ask a good painter about "Blending paint". This is much easier to do with Basecoat/ Clearcoat. Collision Blast.com has an excellent Video (You Tube) explaining Paint Blending . Larry
Old Apr 24, 2015 | 08:36 PM
rktolds's Avatar
Thanks for the input guys. When I get the wagon I'll take some pics. It has original paint but the previous owner kept the front clip.
Old May 10, 2015 | 05:46 AM
twintracks's Avatar
Id try to figure some way to wheel and deal the original steel metal parts back from the seller.
Old May 10, 2015 | 07:59 PM
steverw's Avatar
Buffing the old paint can bring back the color, it just cuts off a little of the dulled surface and gets it down to more of the original color.
Johnd
Nov 28, 2013 08:31 AM
Al2011
Aug 10, 2011 08:58 AM
John Prest
Dec 13, 2009 08:50 AM
lovinbeinamom
Aug 17, 2006 07:49 AM
oldtimeclassics
Aug 3, 2006 11:54 AM
