Rear coil spring interchange between 1964-65 Cutlass and 442
Hello,
I searched through the threads but couldn't find much on the early Cutlass and 442 rear springs. I have a 65 442 that looks like the rear springs have sagged quite a bit. I have a 64 Cutlass that I changed the rear to lowered springs. I figured I could put the coils out of the 64 into the rear of the 65? I couldn't get them to fit as they were too tall. I know these were stock factory springs. Did the 442 model in 1965 use a different spring then the standard Cutlass? Thanks for the help
Steve
Steve
Coil Spring interchange
Yes. I was replacing the rear shocks when I remembered I had the rear coils from my 64. Figured I would put them in to see if they would raise the car a little. Supported the car by the rear frame section and worked the Axel housing to its lowest position, side to side. I still couldn't get them up into the mounts. I probably had a good 12-14" of travel up and down. After not being able to get them installed, I matched the ones I took out to the original 64 springs. The 64 springs were about a 1 1/2" taller than the 65 442 springs I took out. That is why I posted the question if they were different between the years.
Coil Springs
Yes. it does have the factory rear sway bar. Never thought that that would keep the housing from dropping far enough. I will take a look when I crawl under there again. Thanks for the info that they are interchangeable, didn't think they would have two different springs, but you never know.
Steve
Steve
https://classicoldsmobile.com/forums...do-i-need.html
Late reply...IIRC the 64 has a flat perch that the rear coil springs fit on and the 65 442 has a pedestal rising from the rear axle. Will look at my cars tomorrow and check...if it's not raining.
when i replaced the rear springs in my 64, i had to really wrench the springs into place even after disconnecting the shocks.
jensenracing77
January 1st, 2021 05:07 PM
Asusport
August 23rd, 2017 08:01 AM
Legos
June 16th, 2015 09:05 PM
Longhorncutlass
March 2nd, 2009 01:53 PM
