4 dr A-Body Frame 68-72 swap to a 2 dr
Old Mar 26, 2018 | 02:57 PM
James Colvin's Avatar
Hey Does any one know if the frame for an 4 door A-body 68-72 is the same for a 2 door? If not what would you have to do to make it work if at all possible? Would the body mounts be in the same place?
Old Mar 26, 2018 | 04:15 PM
Carshinebob's Avatar
the four door frame is four inches longer. If you shorten a four door frame by four inches between the mid point mount and the next rearward mount (by the lower control arm) you'll have a two door frame. ~BOB
Old Mar 26, 2018 | 05:34 PM
I'm going to go look at the frame if it is what they say it is then might be worth it.
Thanks for the info Bob!
Cheers
Old Mar 27, 2018 | 08:15 AM
lemoldsnut's Avatar
Where are you located?
2 door frames are not that hard to find
Old Mar 27, 2018 | 08:46 AM
I'm located in Ontario near Toronto
Old Mar 27, 2018 | 10:03 AM
If you are considering shortening a 4 door frame then you MAW just repair the 2 door frame. Either way you should be a competent welder to tackle that project.
1968 cutlass
Sep 25, 2017 01:47 PM
alburk
Oct 2, 2016 04:35 PM
71 sienna supreme
Sep 22, 2011 10:52 AM
sixty9olds
Jun 14, 2011 06:43 PM
1969goatman
Aug 30, 2010 07:44 PM
