What size springs do I need
I may be replacing the front and rear springs. Has AC, 350ci. TH350 trans.
What should the unloaded height be for the front and the rear springs. I want it back to stock ride height. I have air shocks that are near new that will be going back on for those heavy loads if I need some extra help. I have the Moog shock list just need what size they should be. I'm doing a frame off restoration.
The front and rear springs look like they may have been replaced. After I get them out I'll measure them. They have burn marks on them and not sure what happened or what was going on?
Burn marks on the spring sounds like someone heated the spring to remove a coil from the spring action, possibly because the spring was incorrect and caused the car to ride too high. Or they just wanted a cheap lowering from stock height.
That is totally dependent upon the spring specifications - it is the loaded height that is important. The unloaded height of different springs can vary depending upon the stiffness of the spring while still maintaining the same loaded height.
Here's a picture of my new Moog 5536 spring vs the old original front spring. The car sat at the same height with both springs.
Below are some front spring specs for various applications I archived a while back. Note the difference in load height compared to the free height.
> 5390 small block - no AC
> wire diameter = 0.650"
> load height = 11.000"
> load = 1952 pounds
> rate per inch = 336 pounds
> free height = 16.808"
> 5382 big block - no AC, small block - AC
> wire diameter = 0.660"
> load = 2066 pounds
> rate per inch = 360 pounds
> free height = 16.724"
> 5400 big block - AC
> load = 2167 pounds
> free height = 17.004"
> 5536 442 small block - AC - heavy duty, 442 big block - no AC - heavy duty
> wire diameter = 0.690"
> load = 1984 pounds
> rate per inch = 488 pounds
> free height = 15.063"
> 5450 small block - AC - heavy duty, big block - no AC - heavy duty, -442 big block - AC - heavy duty
> load height = 12.000"
> load = 1642 pounds
> rate per inch = 454 pounds
> free height = 15.616"
> load = 1952 pounds
> load = 2066 pounds
> 5400 big block - AC
> load = 2167 pounds
> load = 1984 pounds
> load = 1642 pounds
> load = 1952 pounds
> load = 2066 pounds
> 5400 big block - AC
> load = 2167 pounds
> load = 1984 pounds
> load = 1642 pounds
> load = 1952 pounds
> load = 2066 pounds
> 5400 big block - AC
> load = 2167 pounds
> load = 1984 pounds
> load = 1642 pounds
Wildcard
December 9th, 2012 10:35 AM
bigjaythe1st
Suspension & Handling
May 8th, 2012 05:45 PM
1acesmith
August 11th, 2011 11:03 AM
NAS Backyard
January 26th, 2009 12:04 PM
