Frame paint question. Blast, POR15 or something else?
I've got a mixture of rust, bare metal and paint. I was thinking of sandblasting with walnut shells but never sandblasted before so not sure if I should. There's POR 15 but I read it is only for over rust.
Whatever media you use have the frame checked for "straight" before refinishing. Walnut shells may not be aggressive enough? Dipping then powder coating would be my choice. Just as important to get inside the frame as the exterior. Im sure you'll get 17 thousand other opinions here.
It's had the quarters replaced with chiniesium and possibly the rockers too so I'm leaving the body on the frame. It drives straight. The suspension is out of it now. If blasting I will be laying under it. Got some Eastwood internal frame spray for inside. Hoping to stop further rust before installing the new suspension. What would be a good media to try that would remove rust with lower chance of blasting thru the metal or is there another option? Thanks for your response.
Looks like I'm blasting. Wish I could do the frame off but I switched jobs and the busy season is 9 months out of the year so just going to make it best I can and drive it.
Now sheetmetal is a different story . Large panels can be warped terribly if sandblasted too aggressively . This is why walnut shells , soda , and other media is used there .
Who dips frames and bodies for that matter in the U.S.(east coast) ? Redi strip IL or IN is one name I came across but thats about all I know? Media blasting and even dustless blasting is fairly common these days but I don't know of many dipping options?
Redi-Strip in Roselle Illinios did it in 2016 because they gave me a quote. Don't know if they still do. They called it chemical immersion.
Edit: their website says they do immersion.
My frame was blasted with walnut shell. You be the judge. Frame painted with Eastwood Chassis Black.
I am weighing the costs of sending it out and doing it myself.
For around 1k IR SS5 L5 compressor is rated at 18.1 cfm at 90psi.
Walnut shells seem kind of mild as a media for a frame. I use crushed glass media with no issues. My compressor is 23.5 SCFM and I have an ancient TP Tools pressure pot blaster. The higher the SCFM, the larger the nozzle you can use and the faster you can strip the frame.
Walnut shells is really for polishing only, use garnet, black beauty, steel shot, glass etc, your not gonna hurt a frame with that much meat, better blast will show you what you need to fix as well as a better bond for the paint..why waste all that time using walnut shells to get white metal, use a more aggressive media, better profile on the blast will get better bonding in the paint.
I did not blast the frame myself I took to a sandblasting company and they blasted my control arms and rear end as well and it was 80.00 per hour and it took them right at 2hrs to blast them. Now I did paint it myself. The thing about blasting yourself is you do have to have a compressor with enough cfm's to make a blasting pot operate and also sandblasting is a nasty job. Now I do have a 50lb blasting pot which I use "sugar sand" as the media. My compressor is an Ingersoll Rand 60 gallon model #2340L5.200-3 which is rated 14 cfm @175psi. It allows me to use any of my air tools with it. I am very happy with the results of how my frame turned out.
I had my frame sandblasted and powder coated for $550 here in Orlando .
It might be worth checking into it in your area .
Powder coat is far superior to any paint as far as resisting chips and scratches .
diesel7477
27
August 17th, 2012 05:34 PM
