Replacement Tierod for 69 Toronado doesn't fit
Old Mar 8, 2020 | 03:19 PM
jortdevries1987@gmail.com's Avatar
Question Replacement Tierod for 69 Toronado doesn't fit
Good day everybody,
During the last two yearly inspections of my 69 Oldsmobile Toronado it was rejected due to a worn-out tie rod.
I quickly ordered 2 new tierods on rock auto according the specifications of my car.
Also I cross-checked the AC Delco part finder to get the correct part.
I asked my local garage to install the tie rod but they, said it didn't fit
when My car was back in the garage I jacked it up to try myself.
I found out that the new tie rod has a different taper fit. the taper is smaller on the bottom which allows the tie rod to slightly deeper down and due to that, there isn't enough thread to fully tight the castle nut.
I added a few washers to solve the problem.
Question 1, Does anyone know which tie rod will be correct for my 69 Toronado
Question 2, what do you think of my solution.
Please note I'm not from the USA but from the Netherlands, shipping parts back and forward can become costly due to the high shipping cost and import taxes, also Oldsmobile pars are very Rare here, so there are not too many places where I can go.
Greetings from Holland
Old Mar 8, 2020 | 03:32 PM
You have the wrong taper tie rod. Doing it the way in the picture may cause the shaft to pull out of the socket.
Old Mar 8, 2020 | 04:26 PM
nicks1966's Avatar
Original part number was 5695507, superseded to 7817093
google search comes up with one
https://www.oldsobsolete.com/product...d-nos-5695507/
Old Mar 9, 2020 | 07:08 AM
I wouldn't drive my car like that! Worn tire rods are preferable to tie rods with the incorrect taper. You should be able to get generic tie rod boots for your old tie rods (not sure if these are the correct size though).
Amazon Amazon
If you don't want to order another part from the US then find some tie rods at your local auto parts store and take the boots off of them for your old tie rods. BTW, did the local inspector pass your car with the washers on the tie rod? If so, then...
Ultimately, you need to remove those tie rods and get RockAuto to refund your money. Good luck!
Old Mar 11, 2020 | 01:11 PM
An update from my side
I didn't drove with the washers as I wash doubtful as well.
I will return the wrong parts.
And I ordered a NOS tie rod from Ebay. It will be delivered next week and I hope they will fit.
It seems that some of the '69 Toronado's used the tie rod's from the ''66 up to ''68 models.
I will keep you updated.
Old Mar 12, 2020 | 06:16 PM
rocketraider's Avatar
Oldsdruid
66-72 use the same steering components. 73-78 are different. RA shipped you the later style tierod end. People converting earlier Toronado to later style disc brakes run into this all the time.
Old Mar 17, 2020 | 01:50 PM
A update from my sight,
I just recieved a NOS tie rod from Ebay and it fits perfectly.
it was produced by Perfect Circle chassis parts under nr 269-2179
@ rockettraider, my olds still has the drum brakes,
Old Mar 17, 2020 | 01:54 PM
Glad you got the right one. Looking at your sway bar bushings, you may want to inspect/replace all the rubber bushings in your front end.
Old Mar 17, 2020 | 02:51 PM
^^x2^^ Those front sway bar end links are toast. Order/Install new front sway bar end links. Order up a new set of front sway bar mount bushings, as well.
Old Mar 17, 2020 | 02:56 PM
Do an Amazon price check on the part numbers for Moog. Often free shipping via Amazon. I've been very satisfied w/ Moog products.
https://www.rockauto.com/en/catalog/...+bar+link,7580
https://www.rockauto.com/en/catalog/...r+bushing,7624
Old Mar 18, 2020 | 05:00 AM
Excellent!
STYLLES614
17
Jan 19, 2020 12:34 PM
boese1978
Mar 8, 2016 03:49 PM
shovel55
Sep 30, 2012 11:53 PM
7DeuceDeltaRag
Jun 10, 2012 11:55 AM
craftsman1956
Suspension & Handling
Jul 16, 2010 09:56 PM
