Power steering problems
Old Jul 10, 2021 | 04:03 PM
Reese Neis's Avatar
Ok on my 81 cutlass my power steering went out both the pump and the main pressure hose I couldn’t find the hose anywhere so I had one made out of hydraulic hose and I’ve went through two pumps now one from rock auto didn’t work was defective right away and the other came straight off of another car I’ve bled and flushed the system and I still have no power steering I don’t know if that hose being made from hydraulic hose would make a difference or if there’s something I’m over looking but I’m really frustrated here and kinda at a stand still cause I’m not sure what else could be the issue any help would be greatly appreciated the car does have a hydroboost system
Old Jul 10, 2021 | 04:40 PM
jaunty75's Avatar
How hard did you look? Rockauto shows availability of power steering pressure hoses for all of the various flavors of '81 Cutlasses. You don't way what engine is in the car, but here's their listing for the 260 V-8.
I'll be if you went to your local O'Reilly's, Autozone, or NAPA, they could get you one as well.
Old Jul 10, 2021 | 04:55 PM
Reese Neis's Avatar
I need one that’ll work with a 5.7 olds diesel that’s what the car originally had in it and that’s what the pump is for I work at Napa and I looked on our parts system and we couldn’t get one without custom ordering it and as far as I know rock auto didn’t show me anything for that
Old Jul 10, 2021 | 07:44 PM
jaunty75's Avatar
Rockauto shows availability of the pressure hose for a Cutlass diesel as well.
Old Jul 10, 2021 | 08:27 PM
Reese Neis's Avatar
Ok but do you think that’s the issue is that I made it out of hydraulic hose instead getting the actual hose for it
Old Jul 10, 2021 | 08:58 PM
rocketraider's Avatar
Oldsdruid
Long as it's the right inside diameter should make no difference. That's what PS pressure hose is, is hydraulic hose.
You've got the PS and hydroboost hoses routed correctly, right?
Old Jul 10, 2021 | 09:00 PM
Reese Neis's Avatar
yes they’re all routed correctly
Old Jul 10, 2021 | 10:22 PM
A member had a similar issue a while back and the pressure valve that goes into the port where the high side hose connects was installed backwards.
Old Jul 10, 2021 | 11:28 PM
Reese Neis's Avatar
that wouldn’t be an issue though if the pump hasn’t been apart would it
Old Jul 11, 2021 | 09:26 AM
From what I understand, all it takes is removing the pressure hose to access the valve. The valve just slips into the hose fitting.
Old Jul 11, 2021 | 09:51 AM
don71's Avatar
same but different
There is a short video at this link concerning that valve.
http://www.powersteering.com/blog/20...teering-system
Old Jul 11, 2021 | 12:50 PM
Oldsdruid
Reese- are the power brakes working? That can help us narrow it down to pump, steering box or hydroboost unit.
Old Jul 12, 2021 | 09:22 AM
Reese Neis's Avatar
no no power brakes or power steering
tgilligan
May 1, 2018 01:27 PM
RROLDSX
May 24, 2017 08:27 PM
Apollo
Jul 14, 2016 04:16 PM
DRXOLDS
May 1, 2011 09:51 AM
gerlof_1
Apr 23, 2008 11:09 AM
