Need to get steered back on course
So I bought the Lares 1353 steering box and the correct rag joint and a power steering hose for an 81 Camaro. Everything installed correctly except there is no way I can use or modify the power steering hose to work. One thread here said to cut one end off and flare for use with my stock pump. I can't even manipulate that hose to come close to fitting.
I would appreciate if someone who has used the Lares 1353 to advise me what parts I need to complete this install for both a low and high pressure hose.
Thanks, Randy
Thanks, Randy
I guess I'll try going with the Lee insert adapters and pitch the new 81 Camaro hose and buy a stock replacement. Hopefully that will work for me.
Lee high-pressure seat insert 40620 Lee Manufacturing 4.00
Lee low-pressure seat insert 40630 Lee Manufacturing 4.00
Thanks for the views I'll post my results.
Thanks guys, I ordered inserts Borgeson 925122 GM O-Ring to Inverted Flare Adapter Set but am now questioning whether the metric thread is "close enough". The whole thing sucks, I should have ordered the standard thread steering box in the first place. Some of these threads can hurt your pocketbook so don't follow this one either.
So I got 3 adapters in the mail today. Two are the same, presumably a spare, and one has a smaller diameter hole. Would the small diameter flare adapter go on the return hose?
Thanks guys
Thanks guys
Thanks Yellowstatue but I've already bought the hoses and the adapters,
I just need to know if I should use the large diametered hole adapters for both hoses or use the small diametered adapter for the return line.
coldwar
March 15th, 2010 06:22 PM
Aussie67Delta88Custom
February 14th, 2008 04:49 AM
