motor mount frame stand spacing
Old Oct 23, 2022 | 01:24 PM
Christopher Rizzo's Avatar
Is there different spacing for the chassis mounting bolt holes between various early a-body motor frame stands. I want to make some motor mount shims for header clearance on a 64 but I'm away from the car at the moment. Does the chevy bolt pattern match the olds pattern or are they different?
Old Oct 23, 2022 | 01:30 PM
2blu442's Avatar
They are different. But the early motor mount brackets for the A-body both small block and big block are the same. Do you have an Olds engine or something else your working with?
Old Oct 23, 2022 | 01:37 PM
I went from a worn out 330 to a 425. Used the original small block stands and with the 2261 motor mounts after all kinds of reading on here. The hooker headers I have are tight on the driver side frame but on the passenger side they hit on the control arm. I was going to make a shim to get the engine up just a little bit but wasn't sure of the hole spacing, I have the dimensions for the sbc stand already but couldn't find the olds dimensions online.
Old Oct 23, 2022 | 01:40 PM
2blu442's Avatar
If its just a small amount you may want to consider putting a dent in the header pipe rather than mess with the motor mount. I've had to do that in the past and for just a street driven maybe weekend at the drag strip I don't think it would make a significant difference in performance. Just a thought.
Old Oct 23, 2022 | 02:00 PM
Each division's frame pads use a different bolt pattern on the crossmember. Chevy is not the same. Are the rubber motor mounts new? Old ones can sag, causing fitment problems.
Old Nov 1, 2022 | 10:17 PM
Yes they are brand new anchor 2261 mounts. Interestingly what I took off the old motor were worn out 2286 which were ford parts but cited as something slightly taller then the 2261’s by a member on this board.
Old Nov 2, 2022 | 05:14 AM
First I've ever heard of this
Old Nov 3, 2022 | 08:51 AM
Joe it actually came from your motor mount application thread. I read it there before my motor swap and was surprised that was the mount on my 330 I removed.
jimvbills
Aug 26, 2016 09:43 AM
blee49
Nov 27, 2015 02:08 PM
Se7enty5
May 12, 2015 08:48 AM
H8D-67
Oct 17, 2014 01:07 PM
69OLDSCUTCONV
Nov 10, 2011 01:59 PM
