Help Needed with Sway Bar Bushings Delta88 1966
Old May 21, 2020 | 01:52 PM
Gauchobyte's Avatar
Exclamation Help Needed with Sway Bar Bushings Delta88 1966
Hi Gents: Please someone advise based on the attached photo is those bushings look correct, They seem to me there is too much clearance to the chassis, or did I have to force the bracket by tightening the screws till it gets there?, Please note the screws are not yet tightened to specs (10lbs.inch) but I stopped since it doesn't look to me at that torque it will reach the chassis or become heavily deformed, Help is very much appreciated. Regards. Raul Martinez.
Old May 21, 2020 | 05:53 PM
Sugar Bear's Avatar
That looks like either the bushing is too tall or the bracket is too short. I don't think tightening that much more is correct.
Did the bushings and brackets come as a kit?
Let's see what others comment...
Old May 21, 2020 | 06:44 PM
On my 67 Delta, all the listings for sway bar bushings were too small - 15/16" is shown in the catalogs, which is not correct. The stock bar is 1". I had to use a bushing for the 1971-up cars that was sized for a 1" bar (Moog K5253). And yes, you have to really compress the bushings to get the bolts started. The bar wants to be tight. Any looseness in the bushings results in wasted motion of the bar and lowers the effective roll stiffness.
Old May 22, 2020 | 03:31 AM
Gauchobyte's Avatar
Sugar Bear: Sway Bar and Brackets are original, bushings not.Best.
Old May 22, 2020 | 03:37 AM
Gauchobyte's Avatar
Joe: Thanks as always, but just to be sure, should the brackets reach the chassis or should the 10lbs.ft torque be the limit?
Old May 22, 2020 | 05:57 AM
The bracket need to by hard up against the frame, compressing the bushing.
Old Oct 31, 2020 | 02:52 PM
Jeremx's Avatar
Bushing photos
Guachobyte, did you find a resolution for this? I'm having the same issue. All bushings showing up via Rock Auto and Summit seem to be the tall version. I got the AC Delco bushings via Rock Auto and they absolutely don't fit.
Joe, the Moog part you listed looks just like the bushings I got. Are they not as tall?
Thanks for any help!
Old Oct 31, 2020 | 04:22 PM
nicks1966's Avatar
the moog ones are to tall also, I got ones that work from inline tube.
INL13145 for a 15/16 bar. only ones I could find that would work.
Old Nov 1, 2020 | 09:03 AM
Gauchobyte's Avatar
Jeremx: not sure they are the correct ones but I finally managed to compress them so the bracket reaches the chassis, but forget about the CSM torque specs. Best.
Old Nov 2, 2020 | 12:49 PM
Jeremx's Avatar
Based on your handle, I'm guessing you're referencing a 1966 but I wanted to be sure. What model did you end up putting these on? And any chance you have photos of them on?
Old Nov 2, 2020 | 01:06 PM
Jeremx's Avatar
These rode pretty flush so I'm trying to find something as similar as possible.
Old Nov 2, 2020 | 01:47 PM
Jeremx's Avatar
Getting a lot of good info from this antique thread..
https://classicoldsmobile.com/forums...ushings-39444/
NotDads442
Apr 25, 2018 07:29 AM
1BOSS83
Suspension & Handling
Dec 14, 2017 06:19 AM
Magna86
Apr 17, 2016 04:34 PM
foo
Sep 29, 2012 04:40 PM
miti12
Alero
Jul 27, 2007 09:56 PM
