Sway bar bushing help
Does anyone know, Is the bushing hole diameter smaller then the bar size or should it be exact? I bought a pair of 15/16 since they should be close but the hole only measures 13/16.
I would use the 15/16 bushings, but I would smear the inside and outside of the bushings with silicone grease (NOT petroleum-based grease, which will attack the rubber bushings) before installation. This extra lubrication will help you get them installed and pulled down properly with the larger bar.
oldzy
Jul 1, 2012 08:05 PM
oldzy
Suspension & Handling
Nov 30, 2010 11:33 AM
