Sway bar bushing help
Old Sep 26, 2012 | 01:25 AM
foo's Avatar
foo
I have a sway bar measuring 31/32 and was wondering if I buy bushings 15/16 be a problem. If it is, where would i be able to find the right size?
Old Sep 29, 2012 | 12:53 PM
foo's Avatar
foo
Does anyone know, Is the bushing hole diameter smaller then the bar size or should it be exact? I bought a pair of 15/16 since they should be close but the hole only measures 13/16.
Old Sep 29, 2012 | 01:34 PM
I would use the 15/16 bushings, but I would smear the inside and outside of the bushings with silicone grease (NOT petroleum-based grease, which will attack the rubber bushings) before installation. This extra lubrication will help you get them installed and pulled down properly with the larger bar.
Old Sep 29, 2012 | 02:40 PM
foo's Avatar
foo
any ideas why the hole diameter is 13/16 for the 15/16 bushing or should it be smaller like that?
Old Sep 29, 2012 | 04:40 PM
Lady72nRob71's Avatar
To ensure a tight fit even after thousands of miles. It is supposed to be like that. The rubber compresses much easier than one would think.
Dbechtel71
Mar 30, 2015 01:46 PM
oldzy
Jul 1, 2012 08:05 PM
oldzy
Suspension & Handling
Nov 30, 2010 11:33 AM
Bunser
Apr 16, 2010 02:10 PM
miti12
Alero
Jul 27, 2007 09:56 PM
