HELP! Gas pedal removal
Old Jun 11, 2009 | 09:10 PM
64starfire's Avatar
I'm going to be working on the floor of the starfire and can't figure out how to remove the gas pedal. I see the threaded block on the engine side of the firewall, and can feel some sort of bolt head on the inside, but the bolt head continues to the base of the pedal. Just put a wrench to the "nut"? Does the 'extended' head of the bolt turn with it? Just really weird ya know...
thanks
Old Jun 12, 2009 | 02:50 AM
Yellowstatue's Avatar
Smile Pedal to the metal
There are two threaded studs with a round ball head that simply pushes into the rubber of the pedal...pull or pry up firmly to remove...if the studs are damaged then you unscrew them out of the floor...
Old Jun 12, 2009 | 07:43 AM
64starfire's Avatar
oh yeah
This Forum + you guys= awesome
R8der4life
Jun 4, 2013 06:51 PM
slowolds
Jul 21, 2010 02:31 AM
Gaz Hog
Jun 25, 2010 04:13 AM
My442
May 2, 2010 04:24 AM
jensenracing77
Feb 7, 2010 05:30 AM
