Growling power steering pump.
Old May 30, 2018 | 05:58 PM
Yes, the fluid level is correct. Rebuilt factory pump, new hoses, G body 442 fast ratio steering gearbox, no leaks, power steering works perfect, just growls like it’s low on fluid. Any ideas? Thanks
BTW, this is on my 69 Cutlass.
Old May 30, 2018 | 06:32 PM
Is the steering hard or soft? Did you get the air out of the system? Are the hoses routed in a tight turn to limit fluid flow?
Old May 31, 2018 | 03:42 AM
jensenracing77's Avatar
I can't speak on the norm but The one I had rebuilt by Power Steering Services did that for the first 50 to 100 miles. It slowly got quieter and quieter and worked perfect the entire time with no leaks.
Old May 31, 2018 | 05:08 AM
I did the G body gearbox conversion years ago. The car drive perfect, the steering doesn’t have the “powerful” steering the factory gearbox had. It only grows at low speed tight turns (like pulling into a parking spot) but it’s kind of embarrassing. It growls like it’s low on fluid, it’s to the proper level (I even overfilled it to see if that would help) with no change.
Old May 31, 2018 | 09:11 AM
RetroRanger's Avatar
72 Olds CS
How's the belt tension on the pump?
Old Jun 1, 2018 | 03:41 AM
The tension is good, new belts and no slippage. The steering isn’t jerky like it would be if the belt was slipping. The pump just growls like it’s low on fluid.
Old Jun 1, 2018 | 06:42 AM
Who did the rebuild on the pump?
Old Jun 1, 2018 | 05:34 PM
I did the rebuild years ago, there was no wear and reassembly went fine. The pump worked fine for years, worked just fine for the G body gearbox conversion, the growl is something I noticed last fall. I’d like to fix it, it’s a little embarrassing. I’m leaning towards pump issues, but I don’t have another one to try.
Old Jul 31, 2018 | 10:32 AM
GTMeach's Avatar
possible leak in pump return hose. wont leak fluid, sucks in air
Nasty455
Jan 18, 2014 05:20 AM
Finn5033
Jul 9, 2013 12:10 PM
Jetstar 88
Apr 17, 2012 04:25 PM
Joffroi
Nov 3, 2011 12:42 PM
1969cutlazz
May 8, 2011 03:04 AM
