Drivers Door wont Open on 72 Cutlass
Old May 23rd, 2008 | 05:06 AM
UCF72Cutlass's Avatar
Anyone know how i can fix this or whats wrong? I press in the door handle and pull the **** from the inside and nothing.
Old May 23rd, 2008 | 06:14 AM
Lady72nRob71's Avatar
To me it sounds like you need to pull the door panel and relube every moving mechanism in that door (hopefully you can get it open first!)
My door was almost that bad. A thorough lube helped a lot.
Old May 23rd, 2008 | 11:03 AM
Oldsguy's Avatar
Past Administrator
So you are saying the door won't open from the inside or the outside either way? I don't have an answer for that. But if you can get the door open the you solution is to remove the door panel and make your repairs as stated.
Old May 23rd, 2008 | 12:07 PM
WD-40 and some luck did the job...thanks guys!
Old May 23rd, 2008 | 12:28 PM
I always believed that stuff is "magic in a spray can"...
Glad it helped. You might want to really get in there and use a thicker oil and lithium grease. The original stuff has long since evaporated or petrified by now. The old grease in my doors and quarters more closely resembled chewing gum that I had to chisel out...
tds
August 14th, 2014 12:52 PM
72cuttthang
July 1st, 2014 02:15 AM
yankees
December 21st, 2012 01:41 PM
bobs 69
April 18th, 2010 09:24 AM
2 door cut
November 9th, 2006 09:28 PM
