Drivers Door wont Open on 72 Cutlass
Old May 23, 2008 | 04:06 AM
UCF72Cutlass's Avatar
Anyone know how i can fix this or whats wrong? I press in the door handle and pull the **** from the inside and nothing.
Old May 23, 2008 | 05:14 AM
Lady72nRob71's Avatar
To me it sounds like you need to pull the door panel and relube every moving mechanism in that door (hopefully you can get it open first!)
My door was almost that bad. A thorough lube helped a lot.
Old May 23, 2008 | 10:03 AM
Oldsguy's Avatar
Past Administrator
So you are saying the door won't open from the inside or the outside either way? I don't have an answer for that. But if you can get the door open the you solution is to remove the door panel and make your repairs as stated.
Old May 23, 2008 | 11:07 AM
WD-40 and some luck did the job...thanks guys!
Old May 23, 2008 | 11:28 AM
I always believed that stuff is "magic in a spray can"...
Glad it helped. You might want to really get in there and use a thicker oil and lithium grease. The original stuff has long since evaporated or petrified by now. The old grease in my doors and quarters more closely resembled chewing gum that I had to chisel out...
tds
Aug 14, 2014 11:52 AM
72cuttthang
Jul 1, 2014 01:15 AM
yankees
Dec 21, 2012 12:41 PM
bobs 69
Apr 18, 2010 08:24 AM
2 door cut
Nov 9, 2006 08:28 PM
