"Bare Steel" paint recommendations
I recently had my VC gas tank repaired and sealed, being a CA car it was still pretty shiny (except for the bottom area) when I pulled it out. But after it was "boiled" out, it's got a dull look to it. Looking for recommendations for a rattle can paint to make it look close to new. I think the same paint could be used for things like the horn relay and such. A few weeks back I was searching for gas tank liners and remember seeing a picture of a painted tank (a coupe or sedan, not a wagon) but darned if I can find it now. Any suggestions would be appreciated.
This is what I painted my gas tank with years ago after I lined the inside. It brushed on great. FWIW, they do have rattle cans too:
https://www.rustoleum.com/product-ca...-rust/hammered
Thanks for the replies! Olds64 that was your car that I saw, I did find the post, it was back in April. https://classicoldsmobile.com/forums...-color-134267/
From that post another suggestion is the Eastwood Tank Tone. Right now I'm leaning toward the Tank Tone. Thanks again!
X4^^ I've used the Rustoleum Dark Steel as well with good results. I let it dry overnight, then baked in my oven for 30-60min at 200 degrees. Turn off the oven and leave it inside until it cools down to where you can handle it without gloves. I've also used PlastiKote Rebuilders Cast #285. for cast iron parts like master cylinders. It doesn't have the metalic flakes like the Rustoleum so it's less shiny more of a matte finish.
Rodney
Rodney
BackInTheGame
November 21st, 2017 06:00 PM
