Anyone strengthen stock motor mounts...?
Old Feb 27, 2021 | 03:22 AM
STLCRZY's Avatar
I have read that some guys put one or two bolts across the stock mounts to strengthen it...
Anyone do this ..?
I have a solid mount here but they dont fit...
Wanna to do this only on driver site.
Hope someone can send me a pic.
Old Feb 27, 2021 | 05:13 AM
Rallye469's Avatar
What’s the need?
Yes, I’ve heard of guys drilling a hole all the way through the center and running a bolt through.
Probably works.
Just use a torque strap or even a chain on the drivers side.
-peter
Old Feb 27, 2021 | 07:05 AM
Originally Posted by rallye469
just use a torque strap or even a chain on the drivers side.
-peter
^^^this.
Old Mar 5, 2021 | 12:19 PM
69455's Avatar
I ran a bolt thru the center for years with no issues prior to going to solid.
Need to drill a clearance hole on frame mount for head/nut.
And the solid mounts had to be tweaked / shimmed from block to fit.
Choose your fight.
Old Mar 8, 2021 | 02:04 AM
STLCRZY's Avatar
Choose your fight.
So you drill a hole across the motor mount and the frame mount ...is this correct ?
Old Mar 8, 2021 | 06:13 AM
oddball's Avatar
No. You just put the bolt through the center of the mount, same direction as the bolts going into the block. The only point of the bolt is to stop the mount from ripping apart where the metal plates are bonded to the rubber. Note that any modern mount has a safety interlock buried in there, so even if the rubber fails, the mount won't come all the way apart.
Old Mar 8, 2021 | 07:33 AM
67OAI's Avatar
Old(s)GuysRule
Or you can spend the bucks for the polyurethane mount that someone on the various Olds performance facebook pages is fabricating. Saw his listing recently on BTR's facebook page.
Old Mar 8, 2021 | 05:52 PM
cjsdad's Avatar
One of the Hot Rod family of magazines had a "How-To" about this back in the '80s. Drill a hole through the motor mount the size required for tapping threads in the inside plate. Drill a larger hole in the outside plate so the bolt shank will then fit through. Use a bolt just long enough to thread through the mount with a very small amount of clearance under the head of the bolt when complete. The theory is that if you have enough power to over stretch the rubber of the mount, the bolt will stop the engine movement before the mount fails but still have the rubber mount without the noise of a of solid. Like mentioned, it's a lot of work since any replacement mount will have interlocking metal plates inside them anyway.
Old Mar 12, 2021 | 02:41 AM
STLCRZY's Avatar
I know the guy and see poly mount, looking good ....and if i locate in your country i would go this route BUT i´m not ....and i dont want to pay more (shipping tax & custom) than i have till now in motor mounts.
Old Mar 12, 2021 | 06:20 AM
67OAI's Avatar
Old(s)GuysRule
Sorry, didn't notice that you are in the EU. Another "trick" that I've heard of is getting a caulking tube of 3M Window Weld P/N 08609, a fast cure urethane, and inject it in the "voids" of a stock motor mount.
Old Mar 12, 2021 | 06:33 AM
oddball's Avatar
That's good for a wide variety of Chevy mounts that are like big hamburger boxes with just a splat of connective rubber inside. But the Olds mounts are pretty solid - no where to inject.
Old Mar 12, 2021 | 08:30 AM
STLCRZY's Avatar
What you about this guys.....?
Old Mar 12, 2021 | 09:10 AM
Looks to me that those bolts will interfere with the engine bracket cross bolt.
Old Mar 12, 2021 | 12:31 PM
oddball's Avatar
Yup, just lop off the extra material and make sure it sits all the way down on the saddle so the cross bolt goes through. Might need to run the bolt in the area closer to your hand in the last picture to be out of the way of the frame mount.
Old Mar 12, 2021 | 12:44 PM
69455's Avatar
Loose the washers
the engine mount needs to sit flat on frame mount.
You will need to drill clearance holes for bolt heads.
1 bolt would do.
Old Mar 12, 2021 | 01:49 PM
green1972's Avatar
on the bottom edge where its open in the above picture, it is a two piece clamshell , cut the excess rubber off and you will see the two pieces and theres a strip about 1 1/2 inch wide you can weld together so it cant open up, still allows the rubber to absorb vibration , but wont open up, a machinist looked at these in 77 and came up with this over the bolts thru because of the interference in the frame bracket, unless you countersink the bolt , Tim
Old Mar 12, 2021 | 06:07 PM
Run to Rund's Avatar
Years ago, I made a jig from an old frame crossmember so I could make up mounts from 1/4" thick plates.
Old Mar 15, 2021 | 08:32 AM
STLCRZY's Avatar
The cross bolt will not touch the two heads of the bolts ..its closely but no contact.
Old Mar 15, 2021 | 08:37 AM
STLCRZY's Avatar
I still don´t have try to mount this motor mount to the frame to see how much space i have ...but yes it really can be that the 2 head bolts areto heigh for the frame mount.
Cant get the bolts wider because it will hit the outer portion of the mout ears ( if you look closely you can see i have cut the washers to get as wide out as i can )
Old Mar 15, 2021 | 09:00 AM
STLCRZY's Avatar
Loose the washers
1 bolt would do.
okay....but can it be that you guys use smaller bolt diamter?
I have use 3/8 Inch bolts and i think i would need to use a milling cutter to get p proper clearence hole for the big bolts...must see
Old Mar 15, 2021 | 09:06 AM
STLCRZY's Avatar
Hey TIM.....Can you tell me if i understand you correct ...weld this like in the pic (blue ?
Old Mar 17, 2021 | 03:35 AM
STLCRZY's Avatar
Crosshaft goes thru the mount.....
... But not if try to mount the motor mount on the frame.... understand.
Old Mar 17, 2021 | 03:47 AM
STLCRZY's Avatar
Can it be that a smaller size bolt(head) would be a better solution?
Old Mar 17, 2021 | 12:59 PM
green1972's Avatar
I have to dig out a spare , i'll try to get you a pic tonight
take the tab and bend it down and weld it
Old Mar 18, 2021 | 06:54 AM
STLCRZY's Avatar
Thumbs up
GREAT Thanks
1971raresx
Aug 18, 2016 08:22 AM
74 fastback
Oct 5, 2015 05:29 PM
madmax442
Apr 14, 2015 05:46 PM
rmoths
Dec 5, 2012 06:50 PM
csouth
Apr 10, 2012 02:19 PM
