69 Cutlass bolt size
Old Nov 4, 2012 | 05:08 PM
Bob69Cutlass's Avatar
Hi All,
There is a common bolt used in the radiator core support area. The hood latch, hood spring etc all use the same bolt. Trying to find the actual size of this item and whether it might be available in zinc coated vs the common black phosphate coating. Also if you know of any sources it would be helpful.
Thanks,Bob
Old Nov 4, 2012 | 05:33 PM
They're 5/16x18, if I recall, and they were used on every GM car made for about 30 years, so they should be no problem to find. NAPA's probably got them, AMK definitely has them, if you've got a lot of money.
Old Nov 4, 2012 | 05:40 PM
Thanks Eric...
Old Nov 4, 2012 | 06:27 PM
Octania's Avatar
http://www.nutsandbolts.com/body-bol...-30_54_80.html
dirt cheap
I could measure one for length if you really need exact info
Old Nov 4, 2012 | 07:19 PM
Octania - the bolts I've removed don't have the attached washer but I'm sure they are out there too....
Old Nov 4, 2012 | 07:36 PM
Also check Autozone. They have a bolt/nut bin with plenty of selection. Either that or a local nut/bolt supply house. I've found that Cad looks good but isn't really worth the extra $$
Old Nov 5, 2012 | 06:16 AM
501Paratrooper's Avatar
If it's the one that occasionally has an anchor on the head, I got them from Fusicks. ILT also carries them.
Del70
Mar 21, 2015 09:22 AM
Alex72cutty
Dec 5, 2014 07:44 PM
Del70
Jul 28, 2014 03:24 AM
Wildcard
Dec 9, 2012 10:35 AM
Kidcutty
Mar 29, 2010 03:23 PM
