64' Full Size - Lower Control Arm Bushings
Old April 17th, 2017, 07:31 PM
Nitroracer's Avatar
The lower control arm bushings in my 64' Fiesta wagon are shot and in need of replacement. Has anyone seen a replacement arm or know of another part that would be compatible? I think I have found the correct AC Delco bushings P/N 45G9012 or Napa NCP 2673217, but I would love to drop in a new arm with a ball joint while I'm at it.
Nitroracer is offline
Old April 17th, 2017, 11:06 PM
chequenman's Avatar
Order up what you need from Fusick. He's got it all. Order online if you want.
chequenman is offline
Old April 18th, 2017, 06:07 AM
Matt, there shouldn't be any reason to replace the control arms on your Dynamic 88. Here is a link to Fusick:
https://www.fusickautomotiveproducts.com/
Kanter is a good source for parts too:
https://www.kanter.com/
Lower control arm didn't come with a ball joint and bushing until much later. I recall replacing the lower control arms on my 1994 Mercury Sable and it was all an integrated unit. Once you remove the control arms from your car you can replace the bushings and ball joint and reinstall it. Everything will be as good as new.
Olds64 is offline
Old April 18th, 2017, 06:12 AM
No one sells new control arms for the 1963-64 full size cars. Good used is your only option. Any 1963-64 Olds full size (Eighty Eight or Ninety Eight) are suitable donors.
joe_padavano is offline
Old April 18th, 2017, 07:29 AM
chequenman's Avatar
Joe:
He asked about Bushings!! and controls arms if he could find them... I sent him to get what would help him out.
Old April 18th, 2017, 07:33 AM
Joe:
He said he already had found the bushings. I was responding to this:
... I would love to drop in a new arm with a ball joint while I'm at it.
Old April 18th, 2017, 05:32 PM
chequenman's Avatar
I see what you mean Joe, I have so many POP Ups on my screen that I had to keep closing one after another just to completely see what you were referring to.
I'm on many different Forums and none have these types of POP Ups happening over and over.
Old April 18th, 2017, 06:47 PM
Get adblocker+ and your popup issue will go away.
oldcutlass is offline
Old April 18th, 2017, 07:21 PM
chequenman's Avatar
adblocker???
I don't have adblocker and I'm not having that issue with other Forums. If I need Adblocker here, where and how do you get it installed and is it for specific Sites??
Old April 18th, 2017, 07:37 PM
Nitroracer's Avatar
Thanks for the info guys. I thought I had come across a loaded control arm on eBay but I lost the link so I can't confirm. New bushings and some time with the press it is.
Old April 18th, 2017, 07:52 PM
Nitroracer's Avatar
I'm going to bet these are not a match: http://www.ebay.com/itm/NEW-UPPER-LO...BX5aF5&vxp=mtr
Old April 19th, 2017, 05:49 AM
Matt, those tubular control arms won't fit your 64 Fiesta wagon. They are for a full-sized Chevy.
Olds64 is offline
Old April 20th, 2017, 07:44 PM
Prior to 1971, Olds full size cars used a completely different chassis and suspension from Impala.
Old April 21st, 2017, 05:14 AM
So, 1971 and up Olds B/C bodies use the same suspension / brakes as the Chevy Caprice and Impala?
Learn something new everyday.
Olds64 is offline
Old April 21st, 2017, 06:38 AM
Suspension, yes.
Brakes, mostly yes. In a few cases the Olds brakes were larger, but all the 1971-76 full size cars used the same 5x5" log pattern and front wheel bearings.
speedaddict78
August 7th, 2013 03:20 PM
Bee-Oh-Pee
June 4th, 2012 11:12 AM
henryk8398
May 3rd, 2012 12:26 AM
HouTXCutlass
March 2nd, 2011 06:16 PM
big_wheel1971
January 23rd, 2010 05:34 PM
Quick Reply: 64' Full Size - Lower Control Arm Bushings
