1969 442 chassis and suspension parts colors
Old Dec 21, 2024 | 01:27 PM
atvron927's Avatar
hi
looking for the correct colors of suspension components front and rear including the rear axle.
chassis frame mounts
control arms front
control arm cross shaft
control arms rear
spindles
steering knuckle
drag link
tie rod ends
tie rod adjuster sleeve
tie rod adj clamps
idler arm
pitman arm
steering box
shocks
springs front
springs rear
front sway bar
rear sway bar
front sway bar u clamps
trans cross member
frame shift rod bracket
rear axle backing plate
rear axle
rear brake drums
caliper
front brake line brackets
rotor hub mine are 2 peace
front caliper mounting bracket
front rotor backing plate
hardware for the above.
thank you in advance.
John Farm
Suspension & Handling
Dec 23, 2020 07:43 AM
Drummerboy1975
Aug 7, 2020 02:50 PM
72455
Apr 13, 2020 06:28 PM
ah64pilot
Sep 1, 2012 08:51 AM
oldzy
Jan 3, 2011 02:38 PM
