1946 Oldsmobile suspension?
Old Mar 7, 2019 | 07:33 PM
Drummerboy1975's Avatar
What type of front and rear suspension does a series 60 club coupe have under it?
Old Mar 8, 2019 | 05:46 AM
I imagine it's short, long arm suspension up front and a solid rear axle in the rear with trailing arms and leaf or coil springs. I suppose it might have king pins up front.
Someone will come along and know for sure.
Old Mar 8, 2019 | 07:30 AM
mpolds's Avatar
Your Front End is:
Your Front End is the King Pins set, Upper & Lower Outer Pin Kits in the Upper & Lower Control Arms at the front end of the arms, Upper & Lower Control Arm shafts with Metal Bushings at the back end of the Upper & Lower Control Arms...
For steering, there is a "tubular" center link and inner tie rods assembly, and then tie rod sleeves, and outer tie rods that go to the wheel.
Then for the Stabilizer bar, there are Stabilizer Links & Sway Bar Frame Bushings.
That is everything for your front end -- the suspension, steering, & the rest....
I have everything in stock Brand New U.S.A. made except the 1 item that would have to be rebuilt only, if it shows too much wear....
Always best to simply call me -- Craig -- 516 - 485 - 1935.......New York......
Old Mar 8, 2019 | 08:18 AM
What about the rear, suspension? I'm looking at acquiring one but I want it lowered. How hard would that be to achieve with a stock suspension
Old Mar 8, 2019 | 10:11 AM
mpolds's Avatar
There is no actual "rear suspension" -- in the rear, the car is "lifted" by Rear Leaf Springs, and its accompanying shackles and bolts...
There are no actual moving parts....
All my parts are stock, are geared toward stock, and that's all the conventional world of parts -- forever -- solely catered to...
If you want it "lowered" --- leave a sagging rear end in there -- and don't replace them....
As far as the front goes; there are outfits out there that will cut your springs -- and re-fit them....
To tell you the truth (because that's all I know) I WOULD NOT do that because cars were not designed to be driven that way -- and you compromise its strength.....
That being said, it is a free country, and you are permitted to do whatever you like.....
Old Mar 8, 2019 | 10:36 AM
​​​​​​Does the rear end sit on top of the leafs? If so, I could just install lowering blocks.
Old Mar 9, 2019 | 05:06 AM
Sporty45's Avatar
Actually, the rear end is not a leaf spring design. It is a coil spring set up with long radius arms. This pic is from a 1940(the only pic I could find), but is basically the same as a 1946.
Old Mar 9, 2019 | 07:22 PM
mpolds's Avatar
Rear End
If Sporty45 has the car, and saw what he has back there -- then there's your answer...
Rear End is not really "my department" -- my coil spring book shows nothing -- and 98 % of the cars back then used rear leaf springs.....
So that "is what it is" and I don't have that car to be able to look at it...
My department is Front End --- all parts right by part #....
Old Mar 10, 2019 | 12:46 PM
47 Convertible's Avatar
You are correct, Oldsmobiles of this era are coil spring rear suspension.
The rear suspension can be lowered by using aftermarket coils. I used 3 inch lowering coils on the rear of the convertible but would recommend 2 inch lowering as I ran into an issue of not being able to find rear shocks that had compatible travel with the lowering coil springs travel. I was grounding out shock travel and ruined one set of rear shocks. I wound up fabricating lower rear shock mounts that allowed a longer travel shock to be used. I could still get the car on a hoist but it was very close to scraping the lower rear shock mounts after all the work was done. Ride was OK but not as good as stock. You give up something to get the look you want.
Google to find the lowering rear coil springs. I didn't keep the receipt so can't give you a company, but was able to source my rear coils from a company in California. Since the coils are a decreasing radius at their ends don't try cutting your stock coil springs to drop ride height.
Jerry
Old Aug 7, 2020 | 02:50 PM
senginc's Avatar
Smile
Moog 5415 rear coil spring for 74 Malibu heavy duty lowered the rear of my 41 Model 76 2 inches. Fit perfectly.
joepenoso
Suspension & Handling
19
Nov 1, 2013 03:05 PM
RetroRanger
Apr 5, 2013 10:23 AM
Mark71
Jan 25, 2012 04:32 AM
1966_F85
May 24, 2010 03:28 PM
Olds luvr
Feb 24, 2009 03:02 PM
