Care and Appearance Washing, waxing, paint care products, etc.
Master Cylinder cast iron appearance
Old Oct 24, 2019 | 04:05 PM
mclark68442's Avatar
Seeking recommendations to keep a new Power Brake Master Cylinder cast iron finish from rusting and looking fresh. Its already installed on the car so I'm not looking at cast iron spray paint. I've seen brush on CI grey, but only in quart cans. A good wipe down with WD-40?
Thanks.
Old Oct 24, 2019 | 05:05 PM
72455's Avatar
1972 U code Supreme
Yup...that's what I did . WD40
Old Oct 25, 2019 | 06:51 AM
Run to Rund's Avatar
I use satin clear from a spray can. Just be careful not to get brake fluid on the "paint."
Old Oct 25, 2019 | 08:36 AM
I've heard that this stuff works great, haven't used it yet though:
https://www.amazon.com/MACs-Auto-Parts-28-76556-Manifold/dp/B071FCCJT6/ref=sr_1_1?crid=1UDYCUMBUPLU0&keywords=calyx+manifold+dressing&qid=1572017643&sprefix=calyx+mani%2Caps%2C152&sr=8-1 https://www.amazon.com/MACs-Auto-Parts-28-76556-Manifold/dp/B071FCCJT6/ref=sr_1_1?crid=1UDYCUMBUPLU0&keywords=calyx+manifold+dressing&qid=1572017643&sprefix=calyx+mani%2Caps%2C152&sr=8-1
Old Oct 25, 2019 | 09:26 AM
MI68442W30's Avatar
WD40 does absolutely nothing to protect it,a better choice would have been brake caliper paint,cosmoline, boeshield even oil is better !
Old Oct 25, 2019 | 12:55 PM
D. Yaros's Avatar
I would use varnish, applied with a brush. The varnish should have a satin finish.
Old Oct 25, 2019 | 02:03 PM
Dave26's Avatar
I did what was done in post #3, about 5 years ago.....still looks like new.....FYI, I had the master cylinder off of the car when I sprayed it with the clear. As stated, brake fluid will eat the clear.
Old Jul 4, 2020 | 05:07 AM
JOHNNYOLDS442's Avatar
Olds Specialist LOL
Wow looks great
UOTE=72455;1205361]Yup...that's what I did . WD40
[/QUOTE]
Old Jul 4, 2020 | 06:33 AM
I've been using the Eastwood master cylinder paint. It's a little too metallic, so it doesn't really look like bare cast iron, but it does stand up to brake fluid.
Old Jul 4, 2020 | 06:47 AM
That's good to know. I've tried several over past years and none worked. I always hear good things about Eastwood products. I might give this one a try.
Old Jul 4, 2020 | 06:51 AM
Oh my...."...pure stainless steel pigment in an ultra durable epoxy ester resin..." I like that!
Old Jul 4, 2020 | 07:06 AM
RetroRanger's Avatar
72 Olds CS
I used the eastwood too. I sprayed it on the car. I used tinfoil around the brakelines and masked off the rest. It came out decent, and still looks good 3 yrs later. I cleared the booster. The master cyl was rusty looking like 72s before picture.
Old Jul 4, 2020 | 07:09 AM
I used the eastwood too. I sprayed it on the car. I used tinfoil around the brakelines and masked off the rest. It came out decent, and still looks good 3 yrs later. I cleared the booster. It was rusty looking like 72s before picture.
That looks excellent. Nice work. That's after three years? Sweet. Thanks for the image.
Old Jul 4, 2020 | 08:48 AM
I like Seymour Paint Cast Blast.
chip-powell
Aug 3, 2015 01:35 PM
Lively72 olds cutlass 442
May 7, 2015 07:52 PM
glidrguy
Brakes/Hydraulic Systems
Aug 4, 2014 09:49 AM
Mr Shifty Sidney
Jun 12, 2013 12:06 AM
68conv455
Sep 16, 2008 10:49 AM
