Master Cylinder paint
I have a 1968 442 convertible that is all stock. My brake master cylinder is beginning to rust at the body right where the lines exit. Is there some kind of paint that I can use to touch this up that will match the silver body of the master cylinder? Thanks.
Keith
Keith
Keith, as you probably know brake fluid and paint do not play together well. I painted mine before I installed it on the car with Eastwoods Spray Cast. I was very careful not to let brake fluid get on the paint when I filled and bled the cylinder. It seems to be holding up OK. You may be able to clean yours really good and do the same.
martine
Brakes/Hydraulic Systems
Feb 5, 2004 10:28 AM
