Line lock questions
Line lock questions
So I got line lock for my 72 cutlass and the directions are poop!
I'm wondering the best way to hook it up. I've read that it's a good idea to put in a brass proportional valve instead of ur cast one!
The directions say that from the pro valve u have your front left and right brake lines. It says to delete the left line (put a plug in the pro valve) and plug it into the line lock. Unscrew the remaining line that is coming from your pro valve (right line) and put it into line lock. So now you have your front right and left lines in the line lock and now you install ONE line coming from pro valve into line lock.
I tried explaining this the best I could but give me your ideas on if you think that would work?
Also what brands of line lock do you guys use and any issues?
Thanks clay
Thanks clay
Thanks clay
Thanks clay
goldie442
Aug 21, 2015 11:01 AM
