Master Cylinder paint
Old Aug 4, 2014 | 08:45 AM
glidrguy's Avatar
I have a 1968 442 convertible that is all stock. My brake master cylinder is beginning to rust at the body right where the lines exit. Is there some kind of paint that I can use to touch this up that will match the silver body of the master cylinder? Thanks.
Keith
Old Aug 4, 2014 | 09:49 AM
Sampson's Avatar
Keith, as you probably know brake fluid and paint do not play together well. I painted mine before I installed it on the car with Eastwoods Spray Cast. I was very careful not to let brake fluid get on the paint when I filled and bled the cylinder. It seems to be holding up OK. You may be able to clean yours really good and do the same.
mbat
Brakes/Hydraulic Systems
Apr 12, 2021 07:40 AM
KQQLCAT
Nov 7, 2016 04:45 PM
Chumley
Oct 31, 2007 09:17 PM
<marksz71>
Oct 20, 2006 07:14 PM
martine
Feb 5, 2004 10:28 AM
