Care and Appearance Washing, waxing, paint care products, etc.
Clay Kit
Old October 27th, 2017, 12:53 PM
BAOKBOB's Avatar
Clay Kit
Anyone ever used a clay kit on their Oldsmobile? Mid to late '70's preferably. Any thoughts will do.
Bob
BAOKBOB is offline
Old October 27th, 2017, 01:30 PM
Proud Viet Nam Veteran
redoldsman's Avatar
Are you talking about the clay bar to clean the paint?
redoldsman is offline
Old October 27th, 2017, 04:53 PM
Platinum Al's Avatar
I use a clay bar on all my cars. Classic and daily driver. I wash my car and then I use the hose water and clay bar. I wet the panel and then clay it. I then rinse. You can use the spray that comes with it, but all the clay needs is a little lubrication and the water is fine. Paint feels so smooth and I notice a better shine. Just keep kneeding the clay as you go.
Platinum Al is offline
Old October 27th, 2017, 08:42 PM
BAOKBOB's Avatar
Yes, Clay Bar. I have never used that system. I just wondered if it was worth all the effort. That is a lot of work it looks like.
BAOKBOB is offline
Old October 27th, 2017, 09:43 PM
I have used the clay bar many times, it removes the fine grit that builds up on the paint that wax will not remove. It gives a smooth surface, good to wax at that point.
1969w3155 is offline
Old October 28th, 2017, 07:12 AM
redoldsman's Avatar
Clay bars get all the impurities out of your paint. Do a spot and then run a cloth over it and you will see the difference. It is not abrasive so do not expect it to buff your paint or make it shinier. I highly recommend it. Meguires and Mothers both make the clay bar.
Old October 28th, 2017, 07:23 AM
BAOKBOB's Avatar
Thanks. I guess I may have to try it.
Bob
BAOKBOB is offline
Old October 28th, 2017, 07:43 AM
Tedd Thompson's Avatar
Just take care that you don't drop it on the floor then try and use it again, instant swirls in the paint..... Tedd
Tedd Thompson is offline
Old October 28th, 2017, 07:44 AM
Gary
VC455's Avatar
Originally Posted by Platinum Al
...Just keep kneading the clay as you go.
Doesn't the removed grit build up in the clay and eventually start to scratch the paint?
VC455 is offline
Old October 28th, 2017, 01:18 PM
BAOKBOB's Avatar
That is what I was concerned about VC.
BAOKBOB is offline
Old October 28th, 2017, 03:21 PM
redoldsman's Avatar
The stuff it removes is not real gritty. It is more like impurities that become embedded in the paint. I might use a clay bar on two cars and then I throw it away. It is getting tree sap and stuff like that out of your paint.
Old October 29th, 2017, 08:29 AM
I think most of the time it is tree sap that won't wash off with regular car soap.I have now started using Race Glaze to do the same job. I like it for getting rid of swirl marks also.... Tedd
Old August 4th, 2018, 11:16 AM
BAOKBOB's Avatar
Has anyone tried the Mothers Clay Bar 2.0? Looks like a rubber pad on a handle. Thoughts?
BAOKBOB is offline
patshotrods
Care and Appearance
September 19th, 2019 11:18 AM
Mr Shifty Sidney
Suspension & Handling
May 6th, 2019 08:54 PM
.Rocket.Man.
15
July 6th, 2014 04:13 PM
1965cutlassragtop
January 24th, 2013 04:17 PM
Prophe'c
September 6th, 2011 07:48 PM
Quick Reply: Clay Kit
