Care and Appearance Washing, waxing, paint care products, etc.
Clay Kit
Old Oct 27, 2017 | 12:53 PM
BAOKBOB's Avatar
Clay Kit
Anyone ever used a clay kit on their Oldsmobile? Mid to late '70's preferably. Any thoughts will do.
Bob
Old Oct 27, 2017 | 01:30 PM
redoldsman's Avatar
Proud Viet Nam Veteran
Are you talking about the clay bar to clean the paint?
Old Oct 27, 2017 | 04:53 PM
Platinum Al's Avatar
I use a clay bar on all my cars. Classic and daily driver. I wash my car and then I use the hose water and clay bar. I wet the panel and then clay it. I then rinse. You can use the spray that comes with it, but all the clay needs is a little lubrication and the water is fine. Paint feels so smooth and I notice a better shine. Just keep kneeding the clay as you go.
Old Oct 27, 2017 | 08:42 PM
BAOKBOB's Avatar
Yes, Clay Bar. I have never used that system. I just wondered if it was worth all the effort. That is a lot of work it looks like.
Old Oct 27, 2017 | 09:43 PM
I have used the clay bar many times, it removes the fine grit that builds up on the paint that wax will not remove. It gives a smooth surface, good to wax at that point.
Old Oct 28, 2017 | 07:12 AM
redoldsman's Avatar
Clay bars get all the impurities out of your paint. Do a spot and then run a cloth over it and you will see the difference. It is not abrasive so do not expect it to buff your paint or make it shinier. I highly recommend it. Meguires and Mothers both make the clay bar.
Old Oct 28, 2017 | 07:23 AM
BAOKBOB's Avatar
Thanks. I guess I may have to try it.
Bob
Old Oct 28, 2017 | 07:43 AM
Tedd Thompson's Avatar
Just take care that you don't drop it on the floor then try and use it again, instant swirls in the paint..... Tedd
Old Oct 28, 2017 | 07:44 AM
VC455's Avatar
Barely Registered
Originally Posted by Platinum Al
...Just keep kneading the clay as you go.
Doesn't the removed grit build up in the clay and eventually start to scratch the paint?
Old Oct 28, 2017 | 01:18 PM
BAOKBOB's Avatar
That is what I was concerned about VC.
Old Oct 28, 2017 | 03:21 PM
redoldsman's Avatar
The stuff it removes is not real gritty. It is more like impurities that become embedded in the paint. I might use a clay bar on two cars and then I throw it away. It is getting tree sap and stuff like that out of your paint.
Old Oct 29, 2017 | 08:29 AM
I think most of the time it is tree sap that won't wash off with regular car soap.I have now started using Race Glaze to do the same job. I like it for getting rid of swirl marks also.... Tedd
Old Aug 4, 2018 | 11:16 AM
BAOKBOB's Avatar
Has anyone tried the Mothers Clay Bar 2.0? Looks like a rubber pad on a handle. Thoughts?
patshotrods
Care and Appearance
Sep 19, 2019 11:18 AM
Mr Shifty Sidney
Suspension & Handling
May 6, 2019 08:54 PM
.Rocket.Man.
15
Jul 6, 2014 04:13 PM
1965cutlassragtop
Jan 24, 2013 04:17 PM
Prophe'c
Sep 6, 2011 07:48 PM
