front sway bar install problem
Old Apr 20, 2012 | 09:42 AM
1965cutlassragtop's Avatar
i bought a 1.25" sway bar from Aadco for my 65 cutlass. it is supposedly for GM 64-72 A bodies & 70-81 f bodies. when i bolt it to the frame then try to connect the sway bar links, the bar seems about .5" too long on each side. i can connect the sway bar links and tighten the nut, but it puts the links at an angle instead of being straight up and down, like this if you are looking under the car from the front- \ /
is this normal?? i asked the vendor i bought it from and they are willing to accept a return if i don't want it, but the sales rep said the links will be at an angle with the thinker bar, does this seem right?? i tend to think i got the wrong bar. so i have a completely brand new front end but right now it looks like i will have to re-use the factory sway bar. any input on this would be appreciated, thanks!!
here is the actal listing for the bar, and i confirmed with the vendor that the part number i received is the correct bar and that the application for my vehicle is correct as well.
http://www.ebay.com/itm/70-81-GM-F-B...fc139a&vxp=mtr
Old Apr 20, 2012 | 09:53 AM
droptopron's Avatar
delete
Do you have it jacked up or on ramps? The sway bar should be installed with weight on the front tires. As the suspension travels the links will go to all sorts of angles.
Old Apr 20, 2012 | 10:04 AM
boese1978's Avatar
X2, w/o the weight of the car the end links look like they are way off for bolting up.
Old Apr 20, 2012 | 10:10 AM
the car was on ramps, yes
Old Apr 20, 2012 | 10:36 AM
droptopron's Avatar
delete
I would contact the manufacturer. I've called them and they were helpful. The catalog lists the same bar '64-'77
ADDCO Manufacturing, Inc.
1596 Linville Falls Hwy.
Linville, NC 28646
1-800-621-8916
Fax: 828-733-1562
Old Apr 20, 2012 | 10:51 AM
so the sales rep i spoke to for Tamraz Auto Parts who said "it is normal for the links to be at an angle with this bar" was completely wrong??
Old Apr 20, 2012 | 11:03 AM
droptopron's Avatar
delete
Call Addco directly and ask them. I have an Addco 1 1/8" on mine and it didnt install like that.
Old Jan 24, 2013 | 04:17 PM
JCMC64's Avatar
JC
Addco 709 bar?d Did you ever ask Addco about this? Was wondering about their answer. I'm going through this right now. Side by side comparison show addco bar is 1/4 inch or so wider. Will post pics later. I originally wasnt as concerned as my car is up on jacks and ive read before about weight needing to be on suspension when installing. Thx.
MDchanic
Suspension & Handling
Aug 18, 2012 05:15 PM
Bluevista
Drivetrain/Differentials
Jun 7, 2010 06:14 PM
oldzy
Apr 24, 2010 04:37 PM
rock350it
Feb 17, 2010 08:30 AM
72OKOLDS
Sep 1, 2009 08:03 PM
