Care and Appearance Washing, waxing, paint care products, etc.
Vinyl top peeling - suggestions?
Old April 29th, 2016, 04:43 AM
safray's Avatar
Close-up of vinyl peeling - any way to get this glued back down before it spreads? Original vinyl top on 1970 442. I've tried carpet glue haven't found a way to clamp it down good enough for it to hold.
safray is offline
Old April 29th, 2016, 05:16 AM
lemoldsnut's Avatar
The problem is the top has shrunk over time. I don't know of any way to stretch it. Probably need to start considering a new top.
lemoldsnut is offline
Old April 29th, 2016, 05:21 AM
Maintained
scottv442's Avatar
I used my wifes hair blow dryer to make the vinyl soft again and gorilla glue.
I did this two months ago on my 1970 supreme vinyl top and left it to cure overnight. Still holding today, but time will tell.
As far as clamping goes, try to insert a wedge between the vinyl top and the chrome trim to keep the vinyl flat while curing. Just be careful not to get glue on the wedge too. You might have to do this in stages along the vinyl edge.
scottv442 is offline
Old April 29th, 2016, 05:58 AM
safray's Avatar
Great idea on the hair dryer & gorilla glue! Thanks, I'll give that a try
safray is offline
Old April 29th, 2016, 09:07 AM
safray's Avatar
lemoldsnut; I know I'll eventually be in for a new top, but the rest of it is such immaculate condition I'll hold off for a while if possible - thanks for the response
safray is offline
Old April 29th, 2016, 09:10 AM
Since you don't have any rust under the top I would definitely fix that ASAP. I was thinking contact cement might be a good adhesive to consider.
Olds64 is online now
70Post
November 10th, 2022 09:30 AM
sammy
July 14th, 2015 12:00 PM
auto_editor
Care and Appearance
December 20th, 2013 12:19 PM
hinz57
August 10th, 2010 08:16 PM
cgjon
June 26th, 2006 06:19 PM
Quick Reply: Vinyl top peeling - suggestions?
