Brake line question
Old Jul 9, 2011 | 07:44 PM
defiant1's Avatar
Brake line question
Okay, I am finally installing the complete rear end I got from monzaz. So, I am going to replace the brake lines while I am doing this. On top of my stock rear end the junction between left and right brake lines is bolted to the top of the pumpkin.
Unfortunately, the rear end I am installing does not have this feature (threaded hole) in order for me to do this.
So can I just leave the junction block loose on top of the pumpkin or should I come up with something else?
I believe the rear end was out of a Pontiac Lemans.
d1
Old Jul 9, 2011 | 08:00 PM
TripDeuces's Avatar
Try finding an original bracket or fabricate one. I wouldn't leave that hanging like that. The constant flexing will crack that brake line eventually or cause it to wear through somewhere along the length of the lines going to each wheel attached to the axle tubes.
Old Jul 10, 2011 | 03:56 PM
What Trip said. The bracket can be as simple as a bent piece of steel held by one of the bolts on the rear cover.
Old Jul 10, 2011 | 04:04 PM
defiant1's Avatar
Copy that. Got a bracket and a new rear flex hose enroute.
d1
Del70
Dec 7, 2025 02:13 AM
Maverick
Brakes/Hydraulic Systems
Jun 26, 2013 08:21 AM
davepnola
Dec 2, 2010 09:00 PM
Flye
Jul 31, 2009 04:03 PM
68conv455
May 20, 2008 02:03 PM
