Axle tube brake line tabs alternative
Old Jul 10, 2011 | 05:31 PM
defiant1's Avatar
Question Axle tube brake line tabs alternative
Well it seems I am down to one brake line tab to hold the brake line against the rear axle tube.
Since I do not have access to a welder or welding skills. Is there an alternative to hold the brake line in place instead of using the weld on tabs?
d1
Old Jul 10, 2011 | 05:42 PM
greenslade's Avatar
could use a dab of silicone to hold the line and the tab in place.
Old Jul 10, 2011 | 06:38 PM
Big hose clamps .
Nylon zip ties .
Old Jul 10, 2011 | 07:43 PM
defiant1's Avatar
I was thinking of this as well, but was not sure if the silicone would adhere properly and be durable enough...
Old Jul 10, 2011 | 09:40 PM
gearheads78's Avatar
car guy
Panel adhesive like used in the body shops. Might as well be welded.
Old Jul 11, 2011 | 04:26 AM
69442C's Avatar
X2. Very stong stuff and often called structural adhesive. If you do this, make sure you clean everything as instructed which may also include a little coarse sanding on the areas being bonded.
Old Jul 11, 2011 | 06:26 AM
defiant1's Avatar
Great I will give that a try.
Del70
Dec 7, 2025 02:13 AM
59-59-59
Feb 8, 2011 09:03 AM
diabolic
Aug 24, 2010 10:00 AM
oldzy
Apr 24, 2010 09:13 PM
hinz57
Mar 23, 2009 09:57 AM
