64 cutlass disc brake help?
Old Apr 6, 2011 | 02:08 PM
64 ragtop's Avatar
Installed a body disc kit spindles and all, caliper hits sway bar,no turn wheels,I am not sure if sway bar is correct for car,not original owner,
does anyone know measurement for sway bar from mount bracket to endlink,it seems to long for car end link leans towards rear of car ,any help is appreciated. THANKS
Old Apr 6, 2011 | 07:09 PM
gearheads78's Avatar
car guy
Post a picture. Something is wrong it should not even get close to hitting.
Old Apr 6, 2011 | 08:01 PM
2blu442's Avatar
I agree with Richard, even with the wheels turned as far as they will go the caliper shouldn't be touching the sway bar. Pictures would be very helpful if you can post them. John
Old Apr 7, 2011 | 02:46 PM
64 ragtop's Avatar
Pics of sway bar hitting caliper
I know the car is on stands i already had it all together and on ground,it is same, i just need measurement for sway bar .It is pushing end link towards rear of car/caliper.I called global west for a measurement to just buy a new one but he said he did not know and did not want to open box and measure one, THANKS
Old Apr 7, 2011 | 08:12 PM
2blu442's Avatar
OK, it got dark before I could come up with a loose one to measure. Here's some pictures of a 1972 Cutlass with the bar from a mid-1970's Trans Am on it. 1964-72 should interchange so yours should look similar to this, just not as large of diameter bar. You can see the end link bolt is pretty straight up and down and much closer to the upper ball joint bolt than the caliper. I think the one on your car is not right for your application. Tomorrow afternoon or Saturday I'll dig out a loose one and take measurements for you. John
Old Apr 7, 2011 | 08:36 PM
TripDeuces's Avatar
It looks like the sway bar is pushing the end link backward or is that an optical illusion? Like the bar is too long and extends backward too much.
Old Apr 8, 2011 | 04:40 AM
a64olz's Avatar
My 64, and a loose bar to compare, tape is at c-c of holes
Old Apr 8, 2011 | 06:13 AM
This is easy. The sway bar end links in the photos are too long. Get the correct shorter ones. Problem solved.
Update:
OK, in looking at the photos a little longer, it appears that the sway bar is not an A-body bar. It's likely an F-body bar. These still work, but again, you need the shorter F-body end links.
Mocephus
Oct 1, 2021 09:45 AM
Maverick
Brakes/Hydraulic Systems
Jun 26, 2013 08:21 AM
Ablast
May 21, 2012 07:34 PM
65Delta88J-Scril
Apr 9, 2011 10:10 AM
jon69olds
Wheels and Tires
Feb 11, 2011 11:57 AM
