64 cutlass disc brake help?
Installed a body disc kit spindles and all, caliper hits sway bar,no turn wheels
,I am not sure if sway bar is correct for car,not original owner,
does anyone know measurement for sway bar from mount bracket to endlink,it seems to long for car end link leans towards rear of car ,any help is appreciated. THANKS
,I am not sure if sway bar is correct for car,not original owner,does anyone know measurement for sway bar from mount bracket to endlink,it seems to long for car end link leans towards rear of car ,any help is appreciated. THANKS
Pics of sway bar hitting caliper
I know the car is on stands i already had it all together and on ground,it is same, i just need measurement for sway bar .It is pushing end link towards rear of car/caliper.I called global west for a measurement to just buy a new one but he said he did not know and did not want to open box and measure one, THANKS
OK, it got dark before I could come up with a loose one to measure. Here's some pictures of a 1972 Cutlass with the bar from a mid-1970's Trans Am on it. 1964-72 should interchange so yours should look similar to this, just not as large of diameter bar. You can see the end link bolt is pretty straight up and down and much closer to the upper ball joint bolt than the caliper. I think the one on your car is not right for your application. Tomorrow afternoon or Saturday I'll dig out a loose one and take measurements for you. John
This is easy. The sway bar end links in the photos are too long. Get the correct shorter ones. Problem solved.
Update:
OK, in looking at the photos a little longer, it appears that the sway bar is not an A-body bar. It's likely an F-body bar. These still work, but again, you need the shorter F-body end links.
Update:
Mocephus
Oct 1, 2021 09:45 AM
Maverick
Brakes/Hydraulic Systems
Jun 26, 2013 08:21 AM
