Brake fitting question
So I converted my 70 S to front disc back in 2000, Like all the disc kits the one I used converts to the 71 and up, prop valve down on the frame style system. Well the mc finally died and is leaking bad down the booster. Got a new one with the bleeders from Fusick as well as the hold off valve by the mc as I want it to look correct now. I plan on re-installing the original brake distribution block I took off, so my question is are the fittings the same for the 5 lines between the two blocks? Or will they all have to be re-made?
TIA
Dan
TIA
Dan
matt69olds
Brakes/Hydraulic Systems
Jan 24, 2023 03:52 PM
