Brake fitting question
Old Apr 7, 2026 | 09:03 PM
DJS70cutlass's Avatar
So I converted my 70 S to front disc back in 2000, Like all the disc kits the one I used converts to the 71 and up, prop valve down on the frame style system. Well the mc finally died and is leaking bad down the booster. Got a new one with the bleeders from Fusick as well as the hold off valve by the mc as I want it to look correct now. I plan on re-installing the original brake distribution block I took off, so my question is are the fittings the same for the 5 lines between the two blocks? Or will they all have to be re-made?
TIA
Dan
MPSax
Brakes/Hydraulic Systems
Aug 7, 2025 08:06 PM
matt69olds
Jan 24, 2023 03:52 PM
Jakaitis
Nov 4, 2020 02:59 PM
Sampson
Dec 27, 2013 04:53 PM
mike63078
Mar 5, 2012 10:29 AM
