Vista Cruiser Rear Brake Lines
Old Dec 28, 2022 | 10:23 AM
Cincinnati Rick's Avatar
I installed a 71-VC rear end in my 68-442. The preformed hard-lines from the "T" block on the differential to the wheel cylinders do not fit. The VC wheel cylinder has a different angle where the threaded fitting mates up. I called ILT tech support but they are only accepting email questions, so while I'm waiting for their response, I thought I would see if any of you could help. Beside ILT, are there any other suppliers that would have these hard lines?
Old Dec 28, 2022 | 10:44 AM
The VC axle uses different wheel cylinders and different backing plates from those on other A-bodies. This is due to the use of 9.5 x 2.5 rear brakes as opposed to the 9.5 x 2.0 rear brakes used on all other A-body cars. The backing plates are "dished" more to make up for the extra 1/2" per side, so that the wheel mounting surfaces are in the same place. I've found that ILT is well versed on the 68-72 coupes, less so outside of that.
Old Dec 28, 2022 | 11:02 AM
Hopefully they will be able to help but if not, I'll try to modify the lines I have or bend up some new ones. Being that I'm basically a lazy person, I'd rather just purchase a set.
David Sloop
Vista Cruiser & Wagons
Apr 15, 2021 06:43 AM
Toocool
Dec 9, 2018 04:00 PM
ent72olds
Feb 6, 2012 11:40 AM
Bobsw32
Apr 16, 2010 02:32 AM
442garage
Brakes/Hydraulic Systems
Feb 27, 2010 11:28 PM
