New SS Brake Lines Installed on 75 Cutlass
Old Dec 30, 2022 | 11:28 AM
Tuffnut's Avatar
I can tell you it wasn’t an easy job replacing the rotted steel brake line from the proportional valve to the rubber flex line above the diff. Replaced both lines to each rear wheel cyl,s and both rear wheel cylinders. Didnt remove the dual hump cross member or anything else. It’s a tough spot above the mufflers where the flex attached to the frame.
Anyways , all done and brakes are bled and a stiff neck.
Prebent lines from Inline worked great.
Old Dec 30, 2022 | 12:32 PM
Cincinnati Rick's Avatar
Thankless job but a very important one.
highschoololds
Brakes/Hydraulic Systems
Feb 7, 2020 05:05 PM
quadpack67
Sep 27, 2018 11:51 AM
TomT
Mar 24, 2018 03:00 PM
Freddy B
Oct 25, 2015 08:49 AM
therobski
Sep 3, 2013 01:41 PM
