Disc brake torque spec questioned
Old Nov 29, 2020 | 07:59 AM
ThaDeuce's Avatar
Frankenstein 442 owner
I’ve had this dust shield to spindle bolt back out and ruin my rotor. It is the top attachment point for the dust shield. The torque specs on this bolt is 130 ft lbs. according to CSM.
Isn’t that a bit high for a non-graded bolt? I plan to use blue Loctite and actually bend the tab over on the bolt head to prevent backing out again.
P.S. Prior Owner fix.
Old Nov 29, 2020 | 08:37 AM
That bolt doesn't just hold the dust shield, it is the main load carrying bolt for the caliper bracket. A factory one is high strength. It's not a standard "graded" bolt and does not have the head markings. It's a special bolt with a special thread that only fits that location. I cannot comment on the quality of bolts in aftermarket kits.
Old Nov 29, 2020 | 09:37 AM
ThaDeuce's Avatar
Thank you Joe.
Okie Rocket
Brakes/Hydraulic Systems
Mar 9, 2013 12:24 PM
442Dave
Dec 19, 2011 12:15 AM
CrazedCountryRebel
May 21, 2011 12:54 PM
CrazedCountryRebel
May 17, 2011 09:44 AM
Franks425442
Mar 9, 2011 12:08 PM
