'67 442 rear brake cable
Old March 24th, 2019, 06:22 AM
Rocket Olds's Avatar
My e-brake cable is rusted in place and will not brake loose. I have looked through several threads but did not see anything about the actual installation process of that front cable from e-brake down and through frame. Anyone had experience doing this and what is best method. Start from top and go down or fish it from bottom side and up??? all suggestions welcomed. One of the rear cables is also frozen but I have done those before so that is not a problem. Just never the front portion. Thanks, Mike
Rocket Olds is offline
Old March 24th, 2019, 01:02 PM
mpolds's Avatar
I don't work on cars, so I can't help you with installation, but I am sure MDchanic or someone else on this site will assist you....
I have / make QUALITY brake cables --- don't buy mail order / cheesy / use 'em once garbage brake cables.....
Always best to simply call me -- Craig -- 516 - 485 - 1935.....
mpolds is offline
Old March 24th, 2019, 01:45 PM
If you duck your head under the dash and look under the car, its pretty obvious how it goes. You can take them off and goof around with penetrating oil to try and unstick them, I've found they are usually frayed. Or you can just replace them. You can buy some from Craig above, your local autoparts store, or off the internet like rockauto, inline tube, etc. Here is a link for rockauto below.
https://www.rockauto.com/en/catalog/oldsmobile,1967,cutlass,6.6l+400cid+v8,1376962,bra ke+&+wheel+hub,parking+brake+cable,1696
oldcutlass is offline
Old March 24th, 2019, 01:52 PM
I tried the penetrating oil soaking overnight and freed up one a while back on another car and the next time I set the brake it came unraveled internally. Then I got one from after market store and junk. Then I found original braided type and work great. So this time I am not trying the oiling routine. Especially on the front one that goes to e-brake housing.
Old March 25th, 2019, 08:09 AM
lemoldsnut's Avatar
I have many parts cars can provide good used cables.
Email direct lemoldsnut@aol.com
Larry
lemoldsnut is offline
Old March 25th, 2019, 08:24 AM
thanks I will let you know
Dead Reckon
Brakes/Hydraulic Systems
16
April 6th, 2015 12:48 PM
69'442
March 30th, 2013 07:12 PM
GoodOldsGuyDougie
November 22nd, 2010 08:07 AM
Gaz Hog
June 23rd, 2010 07:52 PM
GoodOldsGuyDougie
May 14th, 2010 11:50 AM
Quick Reply: '67 442 rear brake cable
