Vaccum canister help!!!
Old June 25th, 2008, 12:58 PM
72CUTTY's Avatar
simple question.. where do i connect the vacuum line to the canister? from the back of the carburetor( i have a edelbrock 600cfm) or from the engine where the brake booster is connected?
does it make sense pls help?
72CUTTY is offline
Old June 25th, 2008, 01:05 PM
car guy
gearheads78's Avatar
should go to where you have manifold vacuume at idle. The other one is ported vacuume. I can't remember which is which. Just put a gauge on it to check.
Edit: use the big port where the brakes go. I thought you were talking about the factory bulb for the A/C that sits on the firewall.
gearheads78 is offline
Old June 25th, 2008, 01:06 PM
Lady72nRob71's Avatar
I am not sure which canister you are referring to, so if you can describe it, we can give the right answers.
I would guess the one on the firewall for the A/C but I want to be sure.
Lady72nRob71 is offline
Old June 25th, 2008, 01:11 PM
72CUTTY's Avatar
ok.. i bought a vacuum canister for my power brakes...( http://www.hawaiiracing.com/shop_ima...84a64d5e9c.jpg )
now i dont know if to hook it up from the manifold vaccum or from the back of the carburetor?
72CUTTY is offline
Old June 25th, 2008, 01:13 PM
car guy
Back of the carb is manifold vacuume.
Old June 25th, 2008, 01:18 PM
72CUTTY's Avatar
damn so im confused!!!!!
72CUTTY is offline
Old June 25th, 2008, 01:20 PM
72CUTTY's Avatar
ok so where does the brake booster gets the vacuum from the engine? im asking if i should connect it there or in back of the carburetor?
i hope it makes sense
or to make it easier.. how do i connect the vacuum canister for my power brakes?
this one http://www.hawaiiracing.com/shop_ima...84a64d5e9c.jpg
72CUTTY is offline
Old June 25th, 2008, 01:35 PM
car guy
Booster will now be hooked to the new canister. The canister works as a piggy back storing the vacuume that may not be there in the engine with a big cam. I personally prefer a well set up manual brake system but thats just me.
Old June 25th, 2008, 01:41 PM
72CUTTY's Avatar
ok^^ got that so its gonna be
from where the booster was at first to the canister
and from the canister to the booster right?
72CUTTY is offline
Okay, the original brake booster gets its vacuum off a rear port on the intake manifold.
I circled it in purple on the attached picture. This a a 1972 350.
That metal line runs over to the booster where a rubber hose connects the two.
Old June 25th, 2008, 01:42 PM
You got it!
Old June 25th, 2008, 01:48 PM
72CUTTY's Avatar
^^ thanks you soo much!!!
my original vacuum canister was not connected ,.. so when i bought this one my neighboor was telling me that it was
from the back of the carburetor to the canister
and from the canister to the brake booster.. and he got me confused
72CUTTY is offline
Old June 25th, 2008, 05:21 PM
What would this have been?
Are you talking about the booster (9" can behind the master cylinder)??
There was no factory "vacuum canister" on the 72 for the brakes.
The tube was run from the manifold (circled) to a rubber hose to the brake booster.
I am assuming your engine is a 72 stock Olds?
warrior71
February 15th, 2009 05:25 PM
warrior71
February 5th, 2009 03:20 PM
65Delta88
November 24th, 2008 01:50 PM
1972_442
March 17th, 2008 11:40 PM
a6m5zerosen
January 14th, 2008 05:11 PM
Quick Reply: Vaccum canister help!!!
