Tool to remove Parking brake cable
Old Mar 13, 2021 | 08:03 PM
72Pumpkin's Avatar
I am almost ready to lift the body off the frame but can’t figure out how to get the parking brake cable out and through the hole in the floor of the body. It has an anchor with multiple extensions that a simple pair of pliers can squeeze them together to allow the anchor to just push through. There must be a special tool to collapse all four extensions at the same time. Anyone know what it is called and where I can find it?
Old Mar 13, 2021 | 08:17 PM
mrolds69's Avatar
There is a tool, but for one time use you can improvise. Maybe use a small worm gear fuel clamp for example. I've done them like that in the boneyard.
Old Mar 13, 2021 | 08:18 PM
RandyS's Avatar
There is a special tool, but I also don't know what it is called or where to find one. I used a small hose clamp to pinch all of the prongs to get them started thru the hole, then loosen the clamp and feed the rest of the way thru.
Old Mar 13, 2021 | 08:36 PM
Sugar Bear's Avatar
Yup, use a small hose clamp to squeeze the ears. When tightening the clamp leave enough of the ears uncovered to start them in the hole, put grease on the ears, pull the cable outward and through as you loosen the clamp.
Good luck!!!
Old Mar 13, 2021 | 09:22 PM
Gary's 2 442-S's Avatar
Gary
This is the one I have
Emergency Brake Parking Brake Cable Remover Tool | eBay
Old Mar 13, 2021 | 09:25 PM
I use a hose clamp, but if you just have to have the tool google "parking brake cable removal tool" , there are a bout 20 different styles.
Mr Gadgets
Brakes/Hydraulic Systems
Feb 3, 2021 05:28 AM
Gary's 2 442-S
Nov 16, 2015 02:08 PM
Dead Reckon
16
Apr 6, 2015 12:48 PM
Napoleon Solo
Jul 24, 2014 08:50 PM
1972cutsupreme
Oct 1, 2012 01:12 PM
