Super 88 needs dual
Old Jan 5, 2009 | 12:12 PM
Tony Daytona's Avatar
Super 88 needs dual
Where can I find a dual MC? Also a remote fill? Power booster available?
Old Jan 5, 2009 | 12:27 PM
citcapp's Avatar
Non are available that fit the original 56 unit. You have to go with a after market booster or from a later model car and modify your firewall to install it. I am in the process of upgrading my 57 to disc brakes with the dual power master cylinder. Takes a lot of modification but I believe it will be worth it.
Old Jan 5, 2009 | 12:32 PM
Were you able to find a cheap kit? Discbrakemike is a little deep for my pockets right now, but would love to run disc.
Note though, I'm smoothing out the fire wall too, so wanted to keep it hidden under
Old Jan 5, 2009 | 01:36 PM
citcapp's Avatar
Try scarebirds on the internet. Thats were I am purchased mine. The are also a litte pricy. I have not found anything for less dollars. Several aftermarket hotrod sites have frame mount power boosters. You could go with manual disc brakers and avoid the master booster.
Old Jan 5, 2009 | 02:58 PM
Tony,
I'm not familiar with the 50s cars. Is the M/C under the floor? Why do you need a remote fill?
In any case, pick up any issue of Street Rodder. There are many, many vendors selling dual M/Cs, reduced diameter power boosters, etc. Also, if space for the booster is limited, consider a hydroboost unit..
Jakespeed63
Aug 25, 2015 12:20 PM
valmaye
Feb 19, 2012 10:41 AM
62HOLIDAY
Nov 24, 2010 11:35 AM
aholiday
Jan 11, 2010 05:57 AM
