Replacement Rotors on 70 Cutlass
Old Apr 13, 2012 | 09:26 AM
Troys Toy 70's Avatar
Once Olds Always Olds
Does anyone have recommendations for replacement rotors for a 70 Cutlass? Old ones are shot, and I would like to upgrade a little, but still keep 11 inch, and stock calipers. Looked @ ssbc , powerstop, acdelco, .......?
Old Apr 13, 2012 | 11:14 AM
pcard's Avatar
70 Cutlass SX
Have you tried Inline Tube or Fusik?
Old Apr 13, 2012 | 01:05 PM
Not sure what you mean by "upgrade". The reality is that unless you increase the rotor diameter (which changes caliper brackets and wheels), there isn't much "upgrading" to be done. Slotted/drilled rotors are worthless on the street and won't improve braking. Consider aftermarket high-friction pads, which is about the only option without making the changes you don't want to do.
Old Apr 13, 2012 | 02:21 PM
No, I hadnt tried either of those. Thanks for reminding me.
Old Apr 13, 2012 | 02:26 PM
That really is the question: Do slotted/drilled make a noticeable difference? Or should I take the money I save and put it the OAI hood jar? What would be a pad recommendation?
brown7373
Jun 15, 2014 06:21 PM
oldsmobilia
Brakes/Hydraulic Systems
Apr 18, 2010 07:43 AM
kpdandav
May 18, 2008 09:58 AM
Edveen
Apr 29, 2008 01:05 PM
