Replacement Rotors on 70 Cutlass
Does anyone have recommendations for replacement rotors for a 70 Cutlass? Old ones are shot, and I would like to upgrade a little, but still keep 11 inch, and stock calipers. Looked @ ssbc , powerstop, acdelco, .......?
Not sure what you mean by "upgrade". The reality is that unless you increase the rotor diameter (which changes caliper brackets and wheels), there isn't much "upgrading" to be done. Slotted/drilled rotors are worthless on the street and won't improve braking. Consider aftermarket high-friction pads, which is about the only option without making the changes you don't want to do.
oldsmobilia
Brakes/Hydraulic Systems
Apr 18, 2010 07:43 AM
