Rear disc brakes 67 Cutlass
Old Jan 12, 2016 | 06:18 PM
Roger60's Avatar
Bought a rear disc brake kit from a supplier stated to fit 67 Cutlass 10 and 12 bolt rear axles. The rotors won't fit over the axles, about a 1/4 " too small. Tried it on both a 10 and a 12 bolt rear end I have and won't fit either. I am returning it, but the supplier tells me I must have aftermarket axles. I know for a fact that they are both OEM and original to the cars. Has anyone found a set that fits? Thanks
Old Jan 16, 2016 | 07:14 AM
Roger60's Avatar
Rear Discs
After some research I have found the rear disc kits do not fit the Olds or Pontiac rear axles without machining either the disc or the axle. That does not stop the sellers from advertising that they do.
Old Jan 16, 2016 | 07:25 AM
wr1970's Avatar
Hmm that is bad news I bought a 1967 disc break set up for rear and front but never tried them out! Mine supplied rotors with kit. Looks like this year would be a good time to check when it gets warmer! I have had both kits for several years my round to it is slow.
Old Jan 17, 2016 | 07:25 AM
Roger60's Avatar
Rear Discs
You can always have the axle machined down about a 1/4". Or machine the rotor. Guess they would also have to be balanced. If you are stuck with them that is. I have decided to just rebuild the rear drum system.
Old Jan 17, 2016 | 08:45 AM
wr1970's Avatar
Hmm That is a good ideal 1/4 inch off a rotor will not hurt anything if i have that problem.My 1970 has that much missing on one edge of the rotor flat spot. It has never been a problem! Don't ask!
Old Feb 21, 2016 | 04:33 PM
oldolds88's Avatar
ive got an s10 rear set up im going to use on my 65 cutlass,the axles need to come out to install the mounting brackets so im going to get the axle flange turned down to fit the s10 rotor
kitfoxdave
Brakes/Hydraulic Systems
15
Mar 28, 2013 08:19 AM
Prophe'c
Jan 2, 2011 10:23 AM
Kidcutty
Jan 25, 2010 07:05 AM
veltboy618
Jan 7, 2009 12:03 AM
The Stickman
Dec 6, 2008 03:20 PM
