Rear disc brakes on a B-body wagon?
Old Dec 3, 2008 | 05:52 PM
The Stickman's Avatar
Is there a way to add rear discbrakes to my B-body wagon? It has the 5X5 bolt pattern. I am wondering wether maybe a disc brake setup off a GM pickup would work.
Old Dec 3, 2008 | 06:31 PM
Redog's Avatar
I would look at the Moser or Stange web sites to get an idea if they would work.
BTW an 84 Delta and a B body wagon, I envy you very much
Old Dec 3, 2008 | 06:58 PM
The rear disks from the 91-96 Impala/Caprice should bolt right on.
Old Dec 3, 2008 | 07:42 PM
Thanx Joe didn't know those years had rear discs.
Old Dec 3, 2008 | 07:53 PM
Danny Wiseley's Avatar
You'll probably find more rear discs on '94-'96 Impalas and 9C1 Caprices. . .
Old Dec 3, 2008 | 10:19 PM
65Delta88's Avatar
Do you think that they would fit on a '65 Delta 88?
Old Dec 4, 2008 | 07:35 AM
Redog's Avatar
I don't think so.
The B body cars had a lot of the same parts from 78 to 96. I didn't know the rear disk from a 9C1 or SS would bolt right on though, only the Wagons in the 80's had the 5x5 bolt pattern, the B Body cars were 5 x 4.75
Old Dec 4, 2008 | 07:45 AM
Originally Posted by Redog
I don't think so.
The 91-96 cars (sedans and wagons) all used the 5 x 5 bolt circle. The rotors will fit the earlier cars (assuming it's not a J88) but you may need to machine the hub of the axle shaft or make a spacer to get the rotor centered properly. Similarly, you will need to adapt the caliper brackets, as the bolt pattern on the flanges of the axle tubes may not be the same.
Old Dec 6, 2008 | 11:20 AM
64Rocket's Avatar
The early Cad Seville use the 5x5 bolt pattern. You may have to weld up the brkt holes and redrill. I'm not sure on that. I use the set up on my early 57/64 rear end. Like "Joe" said machine the axle face and I redrilled the brkt to fit my rear end. Now I have four wheel disc. I also used the Seville master cyl.
Gene
Old Dec 6, 2008 | 03:20 PM
Gene
Actually, the 76 Sevilles used the 5 x 4 3/4" bolt circles, 77-79 used 5 x 5. While these also work, these days you're a lot more likely to find whale-body Caprices in a wrecking yard than first gen Sevilles.
507OLDS
May 29, 2013 04:56 AM
kitfoxdave
Brakes/Hydraulic Systems
15
Mar 28, 2013 08:19 AM
Prophe'c
Jan 2, 2011 10:23 AM
Kidcutty
Jan 25, 2010 07:05 AM
veltboy618
Jan 7, 2009 12:03 AM
