Disc brakes: Front & Rear or either/or
Old Jan 1, 2011 | 03:08 PM
Prophe'c's Avatar
Question Disc brakes: Front & Rear or either/or
Debating on benefits of front & rear disc brakes or better of the two for one of my cutlasses ('71) I look to upgrade wheels for as well. Same inquiry on the front & rear sways.
Any thoughts from experience out here
Old Jan 1, 2011 | 03:15 PM
rocket1889's Avatar
I have a 71 Cutlass...I got the front disc only and drums in the rear...car stops incredibly, i dnt feel the need to have discs all around.
Mine has front sway only but will eventually buy rear sway
Old Jan 1, 2011 | 03:23 PM
Prophe'c's Avatar
I was thinking front & rear sways, definite now. And since you mentioned, just front disc may very well suffice!
Old Jan 1, 2011 | 07:02 PM
rocket1889's Avatar
yaa...i am deff going to put a rear sway
and yaa i saved some money by not having to buy the rear discs too and im happy i did because like i said its stops really well....later on down the road once the car is finished then mayb ill throw some rear discs for appearance ...lol
Old Jan 1, 2011 | 07:11 PM
firefrost gold's Avatar
master power has a set up with disk front and 11" rear drums have heard good things on it some of the rear end companies are doing the same thing instead of the high drag disk cheaper and you dont have to mess with the master cylinder or proportioning valve
Old Jan 2, 2011 | 10:23 AM
The Stickman's Avatar
Really all depends on what you want and how far you want to go. You could go all the way to 13 inch rotors and 4 pot calipers. Or just a mild update using parts off another car. Same goes for swaybars. In the end how do you want your car to look, brake, and handle. Only you can answer that question.
costpenn
Oct 1, 2014 01:23 PM
Sestius
15
Jul 22, 2012 11:18 AM
2blu442
Apr 25, 2011 06:52 PM
Kidcutty
Brakes/Hydraulic Systems
Jan 25, 2010 07:05 AM
