Power Steering
Power Steering
My power steering pump is leaking all over the place. I'm pretty sure it is coming from the main shaft that connects to the pulley. I've been having a hell of a time getting that pulley off so far. What does it take to rebuild my pump? Is there just a few seals to replace or is there a whole rebuild kit for them? Any ideas?
It's probably easier and cheaper to buy a rebuilt power steering pump from O'Reillys. If you really want to rebuild it yourself you can probably get a rebuild kit from your local parts store or check out Kanter or Fusicks.
Actually the rebuilt is simple. I did the one in my Custom Cruiser recently. A seal kit runs about $15. The only issue is if the front seal has worn a groove in the pump shaft. If your pulley is pressed on, you need a puller to get it off.
nicks1966
Jan 12, 2014 01:46 PM
