Part identification and need
Old Jan 25, 2022 | 02:32 PM
Prodjbm's Avatar
Bill
I am in the process of switching out the proportioning valve because I went to disc brakes in the back. I am also relocating the proportioning valve because I'm putting headers on the car. Is the piece in the picture, that is bolted to the booster, needed? What is that that piece for?, I never remember seeing one before. Thank you
Old Jan 25, 2022 | 05:44 PM
That is the holdoff / delay valve for the 1970-older front disc/rear drum cars that use a metering block instead of a proportioning valve. The holdoff valve momentarily "delays" the front disc brakes from grabbing to give the rear shoes time to move against the drum. If you are installing a new proportioning valve along with the rear discs, then you do not need to retain the delay valve.
Old Jan 25, 2022 | 07:19 PM
Great informative answer. 👍
Old Jan 26, 2022 | 04:29 AM
Prodjbm's Avatar
Bill
Thank you very much!
glent
Brakes/Hydraulic Systems
Dec 8, 2021 01:22 PM
wr1970
Jun 25, 2021 05:47 AM
ponder48
Aug 2, 2020 02:10 PM
servexcell
Aug 4, 2018 11:17 AM
olds68442
Jul 28, 2015 03:13 PM
